Discuss Last Checklist before I start work tomorrow. Is it ok? in the UK Tiling Forum area at TilersForums.com.
Need help again please guys.....had hold up after hold up, we had a wee wait until the tiles got exchanged but got them sorted and are all the same batch now happily. Then daughter was in hospital and son had an accident so nothing got done.
Anyway....back to it now and I'm worried. Got the floor sorted, noggins in, 25mm ply done, solid as a rock. Primed everything (floor and plasterboard walls) with Primer G then used the Dunlop Tanking Kit to cover the green moisture resistant plasterboard walls around the bath area. There was a waterproofing primer, tape for the wall corners etc and then the tanking compound itself...a thick, gluey kind of stuff. Followed instructions on the tub but 2 days later and the walls feel weird, I'm not sure how to describe it, they just don't feel hard as I thought they would. I think the stuff is dry ok but I sometimes think they might feel very very slightly tacky. Have I got a problem or is it just the rubberised compound I'm feeling?
I also phoned Mapei technical helpline to query if I needed to prime over the tanking but I dont, I just tile over it. Please tell me the tanking stuf isn't about to peel off the wall in big swathes and it's supposed to feel like this? :sick:
I'm also about to use the slc tonight....wish me luck...anything in particular I need to worry about?
I painted the coating on the walls then watched a you tube video and saw that the tiler put the stuff on vertically first and then straightaway went back to the start to second coat it but went horizontally this time. So I quickly went back to paint over it again. It felt dry when I recoated it, but there wasn't a great deal of time between the coats. The bloke in the video was slathering it on thickly so I put more on the second time. :sick: If it still feels the same in a couple of days ...will I need to scrape it off and start again? It does feel different on the wall with the green p/b compared to the wall with the ordinary grey p/b.
I've done the ufh and the slc tonight, I've just finished. I mixed one bag/carton but ran out so had to quickly mix another. There seems to be a dividing line between the 2 loads, will that blend in? The first load was only down 5-10 minutes before I poured the 2nd load, so was still wet. I poured it onto the floor in a corner and then tried to spread it a bit with a trowel, then poured more and did the same etc etc. I wasn't sure how much to try to spread it though...what happens if it's too thick...will it crack?
Looks like I may have been worrying needlessly with regards to the slc. I've phoned Mapei technical (again!...very patient, helpful, peeps there) and chap reckons it will be fine and that if it was going to slump in the deeper places, it would have done so whilst drying.
As the floor seems fine 12 hours later with no hollows or dips, I think it's ok.
On to the matting now..........
Just done one bit of it and I'm worried. There are darker bits but also loads of light bits. How do I know if it's going to stick ok...I'm contemplating taking it up and scraping the floor and not bothering with it. If it's not stuck down properly, that's a real problem isn't it? It would have to be stuck 100% all over?
Done with Keraquick and a 4mm notched trowel btw.
Reply to Last Checklist before I start work tomorrow. Is it ok? in the UK Tiling Forum area at TilersForums.com
