Guest viewing is limited
Discuss Laying porcelain tiles outside in the UK Tiling Forum area at TilersForums.com.
Jeff belledean
Hi all
i intend to lay porcelain tiles externally to form a patio, the tiles will be large format 600 x 600mm probably, should I use an under tile mat such as ditra ? And what is the best way to bed the tiles some suggest troweling adhesive on the back of the tile and then bedding them on sand and cement.
what suggestions can you offer.
many thanks
Reply to Laying porcelain tiles outside in the UK Tiling Forum area at TilersForums.com
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
