Discuss Laying travertine outside on the roof of an extension in the British & UK Tiling Forum area at TilersForums.com.
GatesheadCol
Hi Guys,
Ive been asked to lay travertine tiles on an outside area. The roof of an extension to be exact. The roof is structurally very strong, enough to take the weight. It has been laid with felt however this is being ripped up and covered with 18mm WBP ply.
Firstly is travertine suitable for outside areas in our climate? North east englands to be exact. Im actually thinking of not doing it because ive only doen 2 floors in travertine and although very successfully installed the thought of these tiles cracking with moisture and freezing terrifies me.
Any advice would be greatly appreciated, or if another tiler in the north east fancies taking it on, as I now work full time too then give me a shout.
GatesheadCol
The guy has imported them direct as his business is fireplace surrounds unfortunately. I have read differing opinions on travertine , it can be used outside but the thinking seemss to suggest that our climate is not really suitable for it.
TBH Im terrified of this one lol
One website suggested they should not be laid outside with mortar, just laid over a suitably flat and even surface - Dont get that one unless a bed of sand or soemthing was used.
Pebbs
I couldnt believe what I was reading, travertine is absolutely not suitable for this type of installation. This is a fragile material riddled with air pockets, even with applying a sealer this will eventually wear away and leave the material to absorb water which will eventually break it down.
Save yourself the grief and walk away...
Pebbs
DHTiling
I find some replys very strange from tilers...
Travertine is fine outside.. totally fine.... the thing that isn't fine is the substrate they intend to fit..Personally i would be looking at un-coupling it as well ...I would use the 12mm Aqua type panels glued and screwed and then Ditra..
But trust me, travertine is fine outside..
Reply to Laying travertine outside on the roof of an extension in the British & UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
V
I'm about to order the slate for the kitchen/breakfast room, and need to know whether this is...
2 3 4
19K
I hope to complete in the next few weeks on a 1930's semi and have the idea of laying travertine...
BARRONBATHROOMS
hi, i been out for around a year now with a surgically broken leg and possibly wont get back...
oldgit
Hello I’ve been setting tile for 35 years, however I’m now retired and moved from Wisconsin to...
Topshop
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
