Lazer levels looking to retire the spirit level :)
The red DeWalt you have purchased is accurate to .3mm over a meter, so over a room of 8m you could be out by 2.5mm
the thinnest green I've seen is the bosch gll3 80 green.
3 visibility settings.
this is the difference between the bosch with the second light setting
and one stabila, distant 50cm from the wall
I also have the green DeWalt laser above and it totally changed my tiling life. I've achieved things I would never acheive with just spirit levels. For a professional tiler with many years of work, I always try and invest in the best I can. The cheap lasers aren't accurate enough either.
Using the laser this week I have been preparing a floor for underfloor heating and it was terrible, as much as 35mm out of level across a large room of over 30sqm. I've got the floor level to within 2mm. You can't do that with a spirit level
Did you use the reciever and a staff to do that?
Pretty much similar to spirit levels.
I’m basing this on an average Bathroom (the only tiling I do) being about 8 linear metres on the horizontal plane and being about 1 to 3mm out if I draw a level line around the room.
Anyway, great advise on the Dewalt Gents. Looks like I might need to go shopping. Any places that sell it over the counter?
Been using it some more today and like a lot of things it takes time to get used to a new tool.
One of the things that frustrated me at first was the tripod wouldn't go low enough to get the first row of cut tiles set, but I took the level of the tripod and set it with boxes of tiles and am much happier now, yes the beam is a bit wider than I expected, but I have got used to catching the bottom edge of the line, also it makes reading the tape much easier as it illuminates the measurement.
I can see the benefit for the more expensive levels that throw lines fore and aft for setting out a room square, quicker and green lines being easier to see, but I think this will do me afterall, just need a more suitable tripod.
The one I got was from Screwfix as they had it in stock on a Sunday!
Steve Griffiths,
Steve Griffiths,
Steve Griffiths,
Steve Griffiths,
