LED Strip leaking AC reading.
I opened up a LED lamp that measured leaking AC voltage 70 Vac and sometimes after on is 78 Vac or so. The volt is stable AC and DC no reading.
I have checked with LED lights ON, the leakage is not from the driver, connectors,.... I isolated all drivers, connectors,.... away from frame to determine no AC leak but only LED strip that is glued to the frame. So last result LED strip leaked this AC voltage.
LED Driver Specification: 2 wires, AC 240 Vac 0.33A to 2 wires 24-40 Vdc, max 36W, max 900mA SELV.
LED connection: 5 LED in series, Total LED 120, type 5050 LED.
Measurements:
Driver output NO LOAD: 104Vdc
Driver output LED all ON: 72.8Vdc, 160mA
Ground to LED Strip Negative: 30M ohm
Ground to LED Strip Positive: 40M ohm.
Question:
Why is leaking AC, not DC?
What is SELV?
Continue reading...
