Colour Republic
[FONT="] [/FONT]Ok I’ve got a brand new Limestone fireplace that has been damaged (not by me!)
The header block has a small piece which has sheared off maybe 100mm x 100mm, luckily it isn't a piece that carries or supports much weight, if any at all.
I need a way to repair this and bond it back together. The fireplace is engineered stone rather than solid.
Soooo I was thinking of using Akemi Colour Bond to glue it back together but I’m wondering how thin I can get away with this joint, I’m assuming as little as 1-2mm of adhesive as I know some worktop fitters use it at this thickness but then joints in worktops aren't really structural and more of a filler where as this will need to hold at least the weight of the 100mmx100mm piece of limestone.
Sadly forgot to take some pictures but might do next weekend if I get up to the job.
Anybody have experience of using colour bond in small doses or what would you use to bond two pieces of stone together given that the join will be visible?
Cheers guys
[FONT="]
[/FONT]
Cheers guys
[FONT="]
[/FONT]
