splas
Hi Everyone,
Am hoping someone can help with some advice here.
I have had 120sq mtrs of honed Opera limestone (600x600) tile laid in a renovation over a new slab. The slab has expansion joints in doorways, round the perimiter and down the centre of the largest room (59m2). After laying the new slab & screed some seperate areas were added where doorways/windows have been alterered. The slab was laid & dried for several months before the UFH & screed was poured on top. The screed over the UFH has expansion joints to mirror those in the slab.
The screed over the UFH (wet) had been down some 10 months prior to the UFH being turned on (slowly) & whilst the UFH was pressure tested long before this the UFH was never turned on prior to tiling - despite insisting the builder do this. He said no need as the slab/screed had been down so long & was properly dry.
The tiles were laid with no expansion joints to mirror those in the slab/screed & no de-coupling membrane used (120sq mtrs!). Flexible adhesive & grout were used. After some weeks hairline cracks in the tiles (not grout lines) have started to appear (as feared & expected) and continue to appear. They are over expansion joints, across door-ways & where the slab was extended into new windows/doorways. Many cracks span several tiles.
My question is what to do now - ripping the floor up & rectifying is a prospect I can't face (or afford) & suspect this might damage the UFH in any case for such a large area. The cracks are forthemost part quite 'light' i.e hairline, but not all run in staright lines.
My question is:
1. Should we fill & try to disguise the cracks -if so what with-grout/epoxy, hoping they then look like natural markings in the tiles? If we do this will they crack again in the same place?
2. Should we cut expansion joints into the tile where the cracks have formed & fill with grout or silicone (bearing in mind this could look unattractive in some areas as some cracks are close to grout lines so we would have tram-line effect of double grout lines) . Also will this help avoid future cracking or are we better off leaving and/or disguising those cracks on the asumption that as they have already ocured in those places they will not recurr.
3. Try to replace some of the cracked tiles - but won't they just crack again?
4. Take our glasses off & ignore them!
Or any other suggestions?
Grateful for any help from the experts out there.
My question is:
