Linear drain reccomndations..?
I'm looking for an 800mm against the wall linear drain for home.
I usually use Marmox or Wedi trays which have them built in or a Schluter when i'm screeding the falls but the Schluter one has the outlet to the side and i'm needing one with the outlet in the middle and to the front.
It's going to be screeded in for use with 20x20 mosaic.
Any reccomenadtions?
Kerdi Line F will do it. It's illustrated with the drain facing up the tray, but just as easily installed opposite way round. Very low level too.
That looks just the job Impish mate. 😉
If you've used Schluter drains before like me - you'll know they're just a doddle to install and totally safe!
Even when you have to get "creative" with the falls etc...
Tanking and Wetrooms
Tags Tags
drain
merlecollins,
merlecollins,
merlecollins,
merlecollins,
