Discuss Liverpool DIYER says hello in the British & UK Tiling Forum area at TilersForums.com.
Joggers
I have been checking out some of the details on here to do with preventing showers leaking after I'd started to re grout and the tiles came off. Dug a bit deeper and the plasterboard was soaked. So ripped it all out and bought Knauf Aquapanel.
Now looking to tank with BAL WP1 as aquapanel is only water resistant, have you actually seen aquapanel wet. It absorbs the water but stays sound. Was looking for a good seal at the bottom with the tray and ended up buying Trimlux.
Only problems with BAL Primer APD is it says should use a adhesive coating before using the primer. As BAL say it is water repellent. Anyone got any experience with these products.
Joggers
Grumpy Grouter you asked what I was trying to seal. It is really trying to get the best job so I don't have to re grout in the future and so that water does not get behind the tile and down the back of the tray. I had found this article http://www.waterproofingshowers.com/pdf_files/bridging_wall_ledge_movement_joints.pdf
Very understandable etc and I'd already decided on the BAL system and put up Aquapanel but reading the application manual and speaking to BAL Technical they suggested an application of powder based adhesive before the primer.
Hope this helps. :yikes:
Reply to Liverpool DIYER says hello in the British & UK Tiling Forum area at TilersForums.com
Please can somebody share their knowledge and let me know if I’m on the right track, i.e do you...
V
Evening guys recently got my own place, and really want to sort out the kitchen. I thought my...
Veitchy
V
Hi, DIYer for many years, about to embark on my 3rd big tiling project bathroom, floor with...
5K
p4ulo
Not a question, but a suprising observation of an illusion! My next task has been to come up...
bcd-87
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
