Mapei fuga fresca
Christo1
Hi
Had some mapei ultracolous plus white grout dry a dirty grey in places. Mapei fuga fresca has been suggested, does anyone know if it's any good?
:8:Christo
Hi
:8:Christo
It does what it says, i have changed dirty white grout to jasmine with great success.
Good to know, thanks. Just what exactly is it? Is it a paint or some sort of whitening solution
It looks like those shoe polish bottles you get with a foam pad on the end. Just squeeze to get the pad filled with colour and wipe over the grout. Let it dry and then just wipe any over spill of the tile. :thumbsup:
Sounds easy enough!! So is it more like a dye or a paint?
I guess a dye which must penetrate the grout...dont quote me though i just use it not make it.
Mapei told me to use a clean toothbrush to paint it on with as it would prevent spill on to the tiles :thumbsup:
I used it two weeks ago to change jasmin ultracolour which was down 4 years to grey! Turned out brilliant and it has been washed plenty of times since as a lot a feet has walked over that floor! Still looks great.
Fuga Fresca is a polymer paint for bringing back the colour of cementitious grouted joints in floors and decorated surfaces.
Applications:
Fuga Fresca may also be used to eliminate irregularities in the colour of joints caused, for example, by incorrect application of the mortar, or to eliminate unsightly stains caused during use.
Fuga Fresca helps to obtain joints with a uniform colour, which absorb less water and which are easier to clean.
PDF
English
