Marble shower area
Scottish Mark
I went to quote a job which is a shower cubicle 2.20 by .80 they have 40x40 and 12mm thick marble tiles but on the walls they have marine ply board all over the guy said it would be ok to tile straight on to this is this true or will it need to be skimmed also would weight ratio come in to it as well any help or advice would be grateful
Mark
No not ply in a shower, you would need to prime the ply, i would also tell the customer this is not ideal to tile onto and you wont guarantee the tiling onto ply in a wet area.
hi mark.. you can tile with bal flex or fast flex.......bal flex will be easier as it sets slower setting so will allow you plenty time to tile it.....dave.....
marine ply isnt ideal for a shower but better than standard ply...if there is room line out with 6mm backer boards...
BAL Flex Powder & Liquid
A two part, water-resistant and frost-resistant wall tile adhesive, suitable for use in interior and exterior locations. Suitable for fixing ceramic wall tiles and mosaics and dark natural stone. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, plywood/chipboard, tile backer boards, glazed tiles/bricks, painted walls, glass reinforced polyester (GRP) backgrounds, steel and galvanised steel. Conforms to BS EN 12004, Type C, Class 1T.
Might be abit late, but what about tanking the ply
Second thoughts 12mm might be abit on the heavy side for tanking i would ring bal tech
i dont like tiling on it full stop especially in showers or wet areas, wood can move with moisture or atmospheric changes
Marble shower area
Scottish Mark,
CLAYS TILES,
Scottish Mark,
CLAYS TILES,
