Hi Dylante,
what a great thread, perhaps we should sit down and talk plywood over a beer. and watch everyone else drop around us (smirk). But you're right, there's no 'silver bullet'. The following link has some good comparative info on the extreme effective of different plys,
What is the best marine plywood - Boat Design Forums
but my previous post is just based on personal experience within construction.
When I first started in construction 20 years ago, there was no such thing as WBP, marine ply was the only ply recommended to be used for tiling on in a wet area situation, and we always found it to perform well (as long as you followed the correct guidance on fitting). Tiles always remained fixed. Even if you needed to go and put right someone else's badly installed work, where there may be a leak, or the work was just rough, you'd have a heck of a job removing the tiles.
When WBP came in, we started to see it used everywhere on site. People became over confident with it, and I remember on a few occasions where houses were being constructed during the winter months and progress was up to first floor, floor level, the WBP would be installed and construction would just carry on until the brickies hit the roof line, the chippies would come in, install the roof plate, then the roof and of course finally get a pre roof tile membrane on. All this time the WBP would be exposed to the elements, but it would take no time before you saw delamination and warping. On the tile fitting side, I have been called in to a number of bathrooms where the walls and floors were constructed out of WBP. The builders thought they were doing the right thing, as more alternatives came onto the market, and awareness grew that chipboard floors and plasterboard walls were no longer cutting it, they sought the easiest, most familiar materials to work with. I'm not saying that it wasn't better than the previous, and yes, if you are careful, the outcome may be positive, but the warping that is regularly seen with WBP has always been a concern to me, and something you don't see with marine ply. The other problem seen with WBP is that tiles can sometimes separate from the ply itself. There could be a number of reasons for this, perhaps PVA was used, which may be adequate on marine ply, but certainly not on WBP, which is why I mentioned an SBR primer.
But you're right, there is no silver bullet, you have have to go with what you feel and follow best practice.
All the best
____________________
paulc2012
http://www.oakenstone.co.uk
