Discuss Marine plywood floor for tiles in the Canada Tile Advice area at TilersForums.com.
Spare Tool
Its surprising how thick a carpet plus underlay is, we're probably talking 5mm certainly not more than 10mm higher for tiles and backerboard,, a small slope could be screeded in under the carpet if its still an issue, some sort of thresher would still be needed for carpet to tile transition..
Waluigi
I’ve never understood the thoughts that adding a 6mm tile backer board is too high. I suppose it is if you’ve got old newspapers for underlay and your carpet is the old thin foam backed stuff from the 70’s
Even if you’ve got UFH, 12mm backer board down, the transition is fine. You just work it out in the landing.
Reply to Marine plywood floor for tiles in the Canada Tile Advice area at TilersForums.com
    • Optimistic
My tiles are moving after 3 days of been layed on Cement floor. I used MapeGrip D2. just seen a...
Surrey
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
