Discuss Marmox board installation in the DIY Tiling Forum area at TilersForums.com.
I'm going to be installing marmox boards in my new bathroom onto the brick walls using the dot and dab and dowel fixing method but would just like to clarify what to do at the joints.
In wet areas I've read that you use the marmox waterproof sealing tape and dry/damp areas just self adhesive reinforcing tape. In the dry/damp areas should the tape be covered in a layer of flexible tile adhesive, is that a stupid question? On some of the marmox instructions I've also read that the board edges should have a layer of sealant applied to create a waterproof joint - if the edges are waterproofed in this way why the need for the extra waterproof sealing tape?
Reply to Marmox board installation in the DIY Tiling Forum area at TilersForums.com
    • Friendly
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Keighley
DIY Tiling Forum
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
