MF 32-40a joint Electrical Advice
MF 32-40a joint Discussion ThreadMF 32-40a joint Electrical Advice
Hi all,
Just been on a kitchen remodel, has used the existing cooker feed due to difficulty of run/budget, but the kitchen fitter has kindly put a couple of rows of shelf brackets directly above the cooker switch and perfectly pinned the N to the CPC. Builders being builders seem to think it's fine as the fault "disappears" when the screw in question is removed.
I'm unhappy and will ultimately go and fix and make good at my own expense if needs be, as it's my reputation on the line and responsibility to ensure the installation is safe. Ideally in that scenario though I will fix it by putting an 80mm holesaw through the ceiling, pulling the 6mm back up the oval capping and pulling a new one with it, before applying a MF joint and patching the ceiling.
I can't seem to readily find an MF rated joint that will take 6mm and is suitably rated for the current (currently on a 40A MCB, but fairly sure the cables derated enough through the run that it's not good for it so 32A joint will be acceptable with a 32A MCB).
Many thanks,
MF 32-40a joint for the original thread on Electricians Forums
Electrical Advice
Lou,
Lou,
