Discuss Mitering Dado tiles in the UK Tiling Forum area at TilersForums.com.
Q
qizmaster
Hi..im new to the forum and dont know whether this one has been covered previously...cant find it if it has or not?
Im about to try and finish the top of the tiles in my bathroom(4 foot high) with a dado rail tile(20cm x 5cm).
My question is...how do you miter cut these bow shaped little suckers when your mitering them for the inside and outside corner angles?
They are white gloss too! and i am really worried about chipping the finish..
Any suggestions would be very welcome?:huh2:
Q
qizmaster
Firstly..many thanks Drew and Robbo for your return advice with this one!
I must confess tho' that i too like Lendini have not quite understood the difference between the wet saw for the outside mitres and the 'coping joint'?:huh2:
Surely a single cut on one tile should produce both an outside corner and an inside joint?..Or am i getting even more confused?:huh2:
Droopy
the coping joint is where you scribe the profile of the dado and cut out the shape for internal corners, joiners use it when fitting skirtings...i use my grinder to cut out the shape....:thumbsup:
spot on Andy.
I use it becaue I think it gives a much neater finish when the inside corner is not dead on 90*, which can be quite often.
oldgit
The joints on Dado tiles don't have to match up with the field tiles all the time..it still looks ok with a offset joint.....
true but if the rest of the room match it can look odd if the exs dont.
talking the customer into brickbond borders will help with this problem i also think borders look better this way.
White Room
Over the years I,ve seen on bigger sites where they don,t mitre just run into the corner trim. The reason being is the public could catch scratch thereselfs on the mitres, perhaps when leaving a pub toilet and falling against the wall cutting theirselves or rip clothing and claim for damages. Sounds silly but that is what happens
Reply to Mitering Dado tiles in the UK Tiling Forum area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Hi All I'm looking for some advice from the experts and hope you can help. I've just had a...
Hi all, I’m using split face tiles (10mm ceramic 600x300mm) on one wall and I’m failing to cut...
7K
Time's Ran Out
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Mitering Dado tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
