CCV6
Hi. I am laying floor heating over around 11m2 on a concrete floor. Overall area is 20m2 for cupboards and a utility room. I have bought enough insulation boards 6mm thick for the 11m2 and planned to use plywood to raise the rest.
1) Is it ok grouting plywood to the concrete floor?
2) I would like to use 9mm ply wood so that the 6mm insulation board and 3mm thick heat mats are roughly brought to the same level. Is this wise or should I use 6mm plywood and grout the missing 3 or 4mm?
Thoughts appreciated.
Colin.
Colin.
