Moisture resistant MDF - advice please????
what about the moisture in the adhesive dave (in the two hours, if rapid,12 hours if normal set adhesive ),as mdf is (kinda) laminated........what if the first 1mm/2mm of mdf blow (expand) from the moisture in the adhesive......the tiles are gonna hold up for a while.......but i would not want to do a tap test (knock,knock!).......
Not having been in the trade for very long, I am a little confused by your strong argument about tiling onto MDF. Not so much about tiling onto a wood based product, just that you seem to be implying that BAL, the leading British adhesive manufacturer for tiling are wrong. They quite clearly state in their literature that Mosaic-fix (for instance) can be safely used to tile onto MDF as long as it is done correctly. If you comply with BAL procedures, they will even guarantee the installation for ten years where their products are concerned.
Ardex have a similar assertion with some of their products and I have no doubts other adhesive manufacturers do too.
Weber incidently stipulate that moisture resistant MDF is not a suitable surface to tile onto. Normal stuff apparantly is OK.
Are you saying they are wrong?
Grumpy
grumpy......
i just think there is a more economical and stable way to do things,
i typed a bigger post and my internet crashed....sooooooo............
i am not saying anybody is wrong.....anybody...just if you can get from a to b securely (tried and tested) why go to c,d,e and f.....?
p.s mosaic fix is for mosaics? (does as it says on the tin....?)IMO
p.p.s MDF sould not be used in showers or other "wet" areas IMO
what i am saying is if you are a tiler,and your reputation and livlyhood depends on it............m.d.f......is it any good to tile over?
IMO...regardless of the (possible) soloutions.....is it not better to go back to the tried and tested.....i.e ply (which is still risky....will create a post) ,wedi etc..........
if not for the customer, then for your reputation as a professional tiler.....you can offer value for money and a professional job....... and a guarentee......
p.p.s adhesive manafacturers are never wrong....ever...........it will always be your fault......even if you followed the instructions to a tee.........amount of water,lack of water,too thick of a bed,too thin of a bed, not 70% coverage,wrong adhesive,underfloor heating problem.......not to sat this has happend to me.....being a retailer i have heard the storys........cover all bases...
Have To Agree With Protilers And Tiler Burden Covered Every Angle.
So Nothing More To Add.
Just Make Sure If You Do Anything That Your Adhesive Manufacturer Does Not Guarantee That You Do Not Guarantee It Yourself Even If You Think You Are Saving Client Money.
You Did Not Put The Mdf Up But You Have A Duty Of Care To Advise Your Client The Correct Way Forward.
Johnny
Let me lighten the mood.
The pictures you put up Dave of the kerdi installment,is that one of the chuckle brothers doing the work :grin:
Some of the threads in the tiling forum that have had a lot of views are being bumped up into current discussion. Just walk on by if it's not your flavour right now. Perhaps it'll help somebody out one day, and they become members, and then they post a thread, and professional tilers respond, and then you learn something from them...? Maybe?
Daz,
Gabriel,
Daz,
Gabriel,
