mosaic adhesive?
59peejay
On both end walls i want to put in two strips of 305x305 50 mm mosaics,iwas thinking of tiling the walls leaving a strip till last using a couple of battens then adding the mosaics,i will be using either keraflex or kera maxi for the ceramics,is this the way to do it and what adhesive should i use for the mosaics?.
Also using same mosaics for the 1300x800 shower tray,what adhesive again for these?,thanks.
Same as Kilty, if they are the same thickness as your tiles I would fix as I go and peg to stop any being squashed down, There are some pictures in one of my albums showing travertine borders which were fitted as I went. Dont forget to seal prior to grouting.
:thumbsup:
Depends on how quick you work...for adhesive choice.
The maxi is a very flexible adhesive...:thumbsup:
If your doing a mosaic border use cut tiles
Before anyone asks I did centre the tiles to the pier but the women did'nt like it, came in in the morning and found the husband had his orders and taken the tiles off, so that's what she wanted:yikes:
