Gauging up with addy is by far the easiest, cheapest and quickest method. However requires a bit of practice. One tip, this is the way I do it....
Set your tiles above and below border & allow to dry.
I have a number of gauging trowels /scrapers cut down to width to apply adhhesive,
then use a piece of wood notched out to required depth & scrape along gap when addy sufficiently hardened. Give a final clean and scrape before adhesive has fully set.
It is all about timing !
Apply adhesive and fix tiles ( again I have made a few suitable sized notched trowels for this purpose out of gauging trowels ) cut notches out with angle grinder !
