charlie1
Can't see that working for me. But the dog tooth will work around pips if you are using rapid set to biuld out you can leve it proud around the pips and just as it is on the turn you can scrape it back flush. No need to revisit and not really that messy. Just out of quriosity how would you ensure the adhesive is applied to exactly the same depth so you don't get any lipping and surly a day later the adhesive will still be green how do you stop it from just braking up and crumbling away?
You would think that but surprisingly they do keep fairly rigid enough for you to work on. This method is best for these situations but if the mosaic area needs building out substantially then dog tooth is best. Try it Deano. I've never had any issues with lipping.
