Discuss Mosiac and pencil trim in the UK Tiling Forum area at TilersForums.com.
tfs
Here is an example here of one I did today, in this case due to tiling around door I decided to tile over doorway and down at other side so I used the nails due to tiles sliding slightly as I laid them. I worked my way to each tile when setting the border and if required raised each tile as I went along and supported with nails.
ps. these mosaics are a pain in the backside for cutting around sockets:lol:
bigp747
Do the stilets and mosaics all together and use strips of the cardboard box that the tiles came in as your spacers, leave to set then tile above. You could also make it all up on a strip of 6mm ply and stick the whole lot on this would save time having to wait for the things to set as in my first solution. However this method is best used if your mosaic is much thinner than your main tile. hope this helps.
shogun rua
thanks mate
shogun rua
thanks
Reply to Mosiac and pencil trim in the UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
