My DIY bathroom refit - Lots of advice needed
dazzler9000
I’m embarking on my DIY tiling project. I’ve got lots of questions so I’m hoping you can help me out!!
I’m going to be gutting my bathroom and having a new bathroom suite including a freestanding bath. I’ll be fitting new tiles on the walls and floor. I’ll be using a Norton clipper TT200EM to make the cuts.
The bath will have a mixer tap and shower attachment so the room shouldn't get that wet.
I’ll be using quartz on the floor (300x600), gloss white ceramics for the walls (300x600)and mosaics for a feature wall and window ledge.
Questions!!
1 – The walls are plasterboard and plastered. They have been painted and they have a slight ripple effect on them? Not sure what this is as it was there before we moved in. Will I need to flatten this out or can I tile straight on to it? Will I need to board the walls with a "no more ply" type product?
2 – Will I need to primer everything with an SBR primer?
3 – I currently have ply on the floor over the floor boards. Does this ply need to come up and be replaced with “no more ply” or equivalent
4 – Is it advised to use edging strips or try and join the tiles at the edges? If I go with edging strips, what’s the best finish to go for with gloss white tiles – White or silver? You chaps see this stuff all the time, what’s the best finish, flat or round?
5 – I’ve noticed that the tiles on a lot of websites I’ve seen are are arranged in a grid like fashion and not staggered. Is this the right way to do it or is it simply down to personal preference? Also I’ve noticed that 300x600 tiles can go in portrait or landscape orientation. Is there a right or wrong way to do them and what looks best in your opinion?
6 – Which spacers would I use between tiles (2mm?)
7 - Cutting the edge tile in half on mosaics – (I’ve asked this question on another thread but I may as well ask it here for addition comments). I’m going to be laying two rows of mosaics and I’m a little nervous about the amount of cutting I’m going to have to do, any advice on cutting those nuisance edge tiles.
Adhesives
8 – Walls - Do I need a flexible adhesive for the Walls? Would something like this be OK?
Slow Set Wall/Floor Tile Adhesive Grey 20kg (Adesilex P9)
Do I need something different for the glass/stone mosaics?
9 - Floor - Guessing this would be OK for the floors - Fast Setting Flexible Quartz Tile Adhesive Grey 2 Part
Grouts
10 – I’ve used the Kerapoxy epoxy grout before in my kitchen floor and quite liked it. Should I use this again on the bathroom floor as it will get a little wet?
11 – As the kerapoxy is expensive, would the “Keracolour FF White 5kg” be OK for the walls considering I’m not planning on having water splashing on them all day long?
Sorry for the overload of questions but I’d rather get it right first time :hurray:
Certainly looks the part!
My only critic is you can see the cut out behind the toilet.
Other than that looks lovely!
Do you mean the boxing? Yes, it was a bit fiddly because of the curved shape of the toilet. I could have made that box lower so it would fit tighter but I wanted them all the same height.
That's looking good, be proud what you have achieved, I've saw so called professional Tilers that can't tile to an acceptable standard like that.
Big weeel done..
Bathroom Tiling Advice
Unsolved
dazzler9000,
Ian,
dazzler9000,
Ian,
