My DIY bathroom refit - Lots of advice needed
dazzler9000
I’m embarking on my DIY tiling project. I’ve got lots of questions so I’m hoping you can help me out!!
I’m going to be gutting my bathroom and having a new bathroom suite including a freestanding bath. I’ll be fitting new tiles on the walls and floor. I’ll be using a Norton clipper TT200EM to make the cuts.
The bath will have a mixer tap and shower attachment so the room shouldn't get that wet.
I’ll be using quartz on the floor (300x600), gloss white ceramics for the walls (300x600)and mosaics for a feature wall and window ledge.
Questions!!
1 – The walls are plasterboard and plastered. They have been painted and they have a slight ripple effect on them? Not sure what this is as it was there before we moved in. Will I need to flatten this out or can I tile straight on to it? Will I need to board the walls with a "no more ply" type product?
2 – Will I need to primer everything with an SBR primer?
3 – I currently have ply on the floor over the floor boards. Does this ply need to come up and be replaced with “no more ply” or equivalent
4 – Is it advised to use edging strips or try and join the tiles at the edges? If I go with edging strips, what’s the best finish to go for with gloss white tiles – White or silver? You chaps see this stuff all the time, what’s the best finish, flat or round?
5 – I’ve noticed that the tiles on a lot of websites I’ve seen are are arranged in a grid like fashion and not staggered. Is this the right way to do it or is it simply down to personal preference? Also I’ve noticed that 300x600 tiles can go in portrait or landscape orientation. Is there a right or wrong way to do them and what looks best in your opinion?
6 – Which spacers would I use between tiles (2mm?)
7 - Cutting the edge tile in half on mosaics – (I’ve asked this question on another thread but I may as well ask it here for addition comments). I’m going to be laying two rows of mosaics and I’m a little nervous about the amount of cutting I’m going to have to do, any advice on cutting those nuisance edge tiles.
Adhesives
8 – Walls - Do I need a flexible adhesive for the Walls? Would something like this be OK?
Slow Set Wall/Floor Tile Adhesive Grey 20kg (Adesilex P9)
Do I need something different for the glass/stone mosaics?
9 - Floor - Guessing this would be OK for the floors - Fast Setting Flexible Quartz Tile Adhesive Grey 2 Part
Grouts
10 – I’ve used the Kerapoxy epoxy grout before in my kitchen floor and quite liked it. Should I use this again on the bathroom floor as it will get a little wet?
11 – As the kerapoxy is expensive, would the “Keracolour FF White 5kg” be OK for the walls considering I’m not planning on having water splashing on them all day long?
Sorry for the overload of questions but I’d rather get it right first time :hurray:
1, Remove all paint
2,I prefer the Mapei G primer, if you use sbr thin down to 3 water-1 sbr on the gypsum plastered walls...for plasterboard I would'nt but allways read manufacturer's instructions
3,Hardie or no more ply after removing the ply...how thick is the ply.
4,white or silver is a personal choice, I prefer silver square brushed/mat
5,Your choice, my preference is landscape
6,2mm
7,Manual or wet cutter,make sure the wet saw blade dos'nt chip the glass mosaic
8,For ceramic the P9 white not grey should be fine
9,Do you have UFH and what colour are the Quartz tiles
I know, sorry!!
I thought that might be peoples response but I like to try and do things myself with a little guidance.... It's quite rewarding to have a go yourself as long as things go well that is :smilewinkgrin:
1, Remove all paint
6,2mm
Hi whitebeam,
1 - How would I go about removing the paint? That doesn't sound an easy job?
2 - I've got no preference, I just thought I needed to use the SBR? Should I just use the Primer G?
3 - I can remember without ripping up the current lino.... I'd only put it down to make a good surface for the lino. I was looking at using the 6mm no more ply as it should be OK looking at their website. It will also help to keep down costs as they seem to be spiraling out of control.
9 - No, we don't have UFH. She's found a dark grey quartz that she seems to like..
1, bucket of warm water and a damp sponge should do it mate if it is water based that is... If not get a Stanley and lightly score the paint and remove with a scraper.
2, unless it is fresh plasterboard everything needs to be primed, so yes prime the plaster.... Read the instructions on your specific sbr.
If the floor is solid and hardly any movement as it is your own it is simply down to you, you can either glue (with adhesive) and screw some 6mm James hardie backer boards (would be my choice) and also screw. Or you can simply prime the ply and take the risk be sure to use a 2 part flexible adhesive (bag and a bottle)... The risk is simply your choice.
4, white, chrome, square or round is down to prefference... I personally with white ceramic would go for either square white or round depending on the utilities in the room. Just be sure you get the correct size trim for the thickness of tile you plan to use
Bathroom Tiling Advice
Unsolved
dazzler9000,
Ian,
dazzler9000,
Ian,
