Need some advice on Travertine
And@TCT
Hi Guys,
Starting a job next Tuesday with chiseled edge Travertine (4 set) and would be grateful for any advice/tips on:-
How best to seal ?(before laying or just prior to grouting)
wet cut okay?
Any other
Going to use flexible adhesive(white) and flex grout...
Cheers
best to seal twice before grouting and once after, use a small radiator type roller with sponge head, or a paint brush ( clean one ). all cuts will have to be with wet cutter.
good luck with job and post pics
If it is possible to seal (even if only once) before fixing the tiles then I would recommend it, don't worry if you can't just do as Dave says, but if you don't seal before fixing make sure to remove any excess adhesive quicky and keep the tiles very clean. Best of luck.
Doing the same Opus 4 sized chiseled edge travertine on my own place.
Picture shows.......
Partly laid down (got to do the kitchen/hall/utility room and porch)
Sealed once....so far
Not grouted as yet
Nice work mate.
Have moved this thread to correct forum.
When I set travertine....I keep a "tavy tile puck" and check lippage constantly....making sure the tiles are nice and flat and none stick up. I like to use a 1/4 x 3/8 trowel and
coat the back of the tiles with the flat side to get a good bond. Since travertine is prone to cracking, a 100% bond is desirable.
And@TCT,
faithhealer,
And@TCT,
faithhealer,
