I
Italy
same to battipavMontolit 75p and no need to adjust the height to cut a tile as the handle and scoring wheel are spring loaded
They seem to be the preferred cutter on another certain place 🙄
Try and see if you can find a local stockist so that you can try them and make up your own mind.They both look good an appear to do an equally good job. Is one nicer to use than the other? Is one better made/more robust?
Call ahead and speak with Sam, I’m sure he’ll arrange for you to come in and try both machines.Just seen Pro Tiler are in Northampton. I’m not a million miles from there working a lot of the time. Will try to get in there.
