New Ensuite
I'm not gonna get involved with the tiling comments. Agree with some disagree with others. However, as a plumber who tiles I will frown upon the isos on the shower pipe work. You've left a big hole around the pipes which you'll have to pump full of Silicon before fitting the exposed valve. Personally, you have no excuse for not isolating the water supplies and making these a neater 18mm hole.
Other than that, it's far from the worst I've seen. Snag it with the client, get it done and get paid.
that's true ive seen worse
but if you read
Two days so far
so m8 have u allways worked on your own.
have u never thought of teaming up with a local tiler.
I teamed up 18 mths ago with a plumber, we have done over 30 bathrooms in the past 18 mths and have 7 booked in over the next 9weeks and were both making more than when we worked separately bri still puts his boilers in when im on my tiling days and im doing other things when hes doing his 1st fix . Mondays and Fridays we work together as mondays we rip out and Fridays is finishing and polishing
I work with a heating engineer who hates bathrooms. His plumbing is first rate and he trained as a joiner too. I like to think my tiling is pretty good and between us for the past 8 years we've knocked out work we're both proud of. we make a good team.
but if you read
Sounds like a good set up, and is ideal if you can keep a good flow of work, and have a reliable supplier of everything you need. Who was getting the bathrooms jobs in, yourself or the plumber?
that sounds like bri my plumber loves his machine bend pipework hates plumbers who work in plastic and tiling did his head in plus if w ehave aproblem we can throw ideas back and forth till we come up with the answer
we both do. were getting mainly from 2 bathroom companies as well as our own from bri.s regular clients who he services his boilers that hes fitted over the years
I trained my son to do tiling hes now getting trained off brian to be a plumber
Him initially but now it's more 50/50 - all high end stuff and purely on recommendation (which I reckon is the best way)
dQUOTE="impish, post: 804451, member: 28366"]Him initially but now it's more 50/50 - all high end stuff and purely on recommendation (which I reckon is the best way)[/QUOTE]
us to had to cut and shape a resin quartz sink work top on Friday was 1200 quid could of been expensive if I got it wrong the client loved it we got 3 crates of bud which ime drinking now when we left on Friday and money in the bank sat morning also 2 referalls for his neighbours
New Ensuite
JCSplumbing,
MW Smith Ceramics,
JCSplumbing,
MW Smith Ceramics,
