Discuss New Rubi 93 not cutting 18mm porcelain in the Canada Tile Advice area at TilersForums.com.
Deleted member 51481
Hello, just bought one of these to cut large format porcelain tiles and whilst it snaps 10mm porcelain tiles no problem, I can't cut the 18mm variant despite the spec stating it can cut up to 20mm. Have I missed the small print somewhere that 20mm excludes porcelain? I'm using the scoring wheel it shipped so do I need to change this?
Any advice welcome as I fear I may have to return it and use the nuclear option which is a Stihl disc cutter but I only wanted to use that as a last resort.
Hi Caley, most 18-20mm porcelain is 'bomb proof'! There are cutters out there will score and snap it but I've never used one, I'd be interested to see the finish of the cut edge. I tend to use a angle grinder with a turbo diamond blade but if most of your cuts are straight, try to look into it hiring a wet table saw. There is a certain knack to cutting the thicker porcelain as it can 'pop' and randomly crack. Try to cut at each end of the cut line first then 'score' the tile all the way along the cut line with a shallow cut just through the surface, then just cut through gradually. I tend to sit the tiles on a thick piece of celetex foam when cutting. Good luck 👍
The 20mm porcelain is gaining in popularity but I try to avoid it as tend to feel it in my lower back doing the larger stuff. Plus never keen on outside work when having to factor in the weather (that may change after all this!). But it falls into a grey area with it being a job most landscape gardeners wouldn't want to tackle (as rectified, allowing 2mm grout joints with zero lippage) or tilers having to take on adding a whole new element to guaranteeing work that has to withstand the elements over a number of years. Could become a specialist section of tiling on its own.
Reply to New Rubi 93 not cutting 18mm porcelain in the Canada Tile Advice area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
    • Winner
Hi guys, I've just started a job today with a 60x60 glazed gloss porcelain cararra effect. I'm...
8K
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Hi , I've recently been in a job using 750x750 5mm porcelain tiles, they cut fine on the score...
6K
One Day
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
