RubiUK
Hi Everyone,
Just to advise you of a great new RUBI tile cutter available as of today in the UK Market.
The DC 250 1200 is an electric tile cutter with maximum precision and functional moving head. Great for ceramics, stoneware, porcelain and other materials Available in 230v (ref:55941) and 110v (ref: 55943) It has a 1.5 cv/hp motor. With a cutting length of up to 120.5cm (85x85cm) it also cuts material up to 85mm thick. It has a full blade cover so you are able to use any blade, not just a continuous rim one. The engine is set with sliding bearings and the cutter comes with an aluminium bracket adjustable from 0° to 60°. The removable aluminium table makes the machine very easy to clean and the folding legs with built in wheels makes the cutter easier to transport. A CEV 250 blade comes with the cutter although the power cable is supplied separately. Additional accessories also available. These machines can be purchased via any of our local reputable RUBI stockists, nationwide. :hurray:
