Discuss New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com.
GazTech
Re: Any new tilers stuck at all, with anything?
Been asked to tile a painted wooden staircase do i just treat this the same as tiling on a plywood floor or is there anything to watch out for.Any help appreciated.
strip all the paint,prime with acrylic primer and tile using BAL mosaic fix,flexible grout is required
recommendation for grout is BAL with GT1 additive,hope this helps regards Gaz
GazLC81
I'm pretty new to the trade and just wondered if anyone had any little tips that can help with getting quicker. Any little thing at all like tips on removing old tiles or tips on marking up etc?
I find that little tips from the vastly experienced guys help.
Just for example someone mentioned that a good way of getting wall adhesive off is to use a steamer.......
Cheers
Gaz
DHTiling
Hi Dan
Just priced job for three small bathrooms. Two of them have chip board floor so i guess i will need to pva them before tiling. never done this so could you give me a few pointers?
Cheers.
hi paul. i used to use ply method on timber floors but for past year or so have been using ditra mat by schluter it is easy to lay and is excellent for bathrooms with there high humidity , and no problems with water ingression through grout joints causing any sub-floors to swell with moisture, give it a go you'll never use nowt else.GOOD LUCK MATE. p.s.
SCHLUTER have an installation manual you can down load
GazTech
Hi Dan
Doing my first porcelain floor next week (Black polished). About 45m, kitchen running thru to utility the loo. what size grout line should I go with? Can I lay them then seal them before grouting?
MFC, Wexford, Ireland
2mm grout line lovely,polished porcelain must be sealed,recommended product Fila polished porcelain impregnator available from guess who! damn I dont think topps are in ireland are they?
DHTiling
if it has rectified edges a 2mm joint will look fine as for sealing i would as this help fill any pores in the tile face thus helps with the cleaning of the floor
also try using lithofinFZ protective impregnator especially for porcelain tiles and offer customer lithofinFX conditioning cleaner for after care of tiles. hope this helps..
Reply to New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com
Amazon Deals: Link supports the forum Black Friday 2024 | Amazon.co.uk Black Friday is an...
Admin1
Merry Christmas and Happy New Year from Tilers Forums! 2025 should be pretty good. The new...
Tilers Community Any of you members of Tilers Community on Facebook? They do a raffle where...
Colin from Accounts
The Welcome Thread Welcome to Tilers Talk people. :) This is not a big forum as you can see...
Admin1
Brand New Now Instock at Tile Choice - Arden Tiles 🚨🚨 Brand New Now Instock at Tile Choice 🚨🚨...
Admin1
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
