Discuss New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Re: Any new tilers stuck at all, with anything?
rectified edges are just that the edges of the tiles are cut perfectly sqaure no chamfer to edges of tiles, as regards to 2,3 4, + mm grout joints, bs 5385 does not state grout joint widths as these can vary form tile 2 tile depening on tile format and type of tile used.
Dunnster
wivers
I have had to tile a floor that was slanted. Same thing, the customer just wanted it done whatever the outcome. Just tile as normal if the floot is flat and the tiles will lay to the slant. Just be sure you get the customer to sign something saying they wanted to go ahead without rectifing the problem.
Also i would probably have gone a bit higher withe the price m8 but that aint too far off :). Around £30 per sqm for floors is what i look to get including the bits, but its your call m8 and if you think that price wins you the job then thats what matters to start with. Good luck mate.
GazTech
Re: Movement Joints?
Hi, I plan to tile my kitchen/dining room floor but there is two different surfaces. Mostly floorboards, but also a small section of conrete about 2 square metre. The surface needs plywood and self leveling to make level. Is there any way that I can avoid using a movement joint?
I would board T & G boards with 6mm hardibacker boards,and screed the concrete up to its edge.Use a two part flexible adhesive onto boards and across where the joint is,then standard adhesive for the concrete.Your grout should then all be wide joint with BAL GT1 polymer added to give flexibility,no need then for an expansion joint at all using this method,hope this helps Customizer
DHTiling
doin it that way gaz isn't allowing for the fact the two subtrates expand at different rates putting stress on the surface were they meet, surely in time tiles will debond mate!!
p.s. dont want to undermine your comments just thought id mention this.
GazTech
No worries D. I think that within a small area such as this one, using two part flex will be fine and be flexible enough to cope with the limited expansions and contractions of both substates.You do have a good point however, it would only be a concern if the areas were much greater.
GazLC81
Just read your comments about the floor I ask about, the slanted one. I decided to hike the price a little as I wasn't sure it was going to be straight forward. I up'd it to £325 but I haven't heard back yet. I'm not sure I want to do the job tbh, not sure the customer will pay. I may be wrong but I just get a feeling.
Gaz
Reply to New Tilers Support - 1 in the British & UK Tiling Forum area at TilersForums.com
Amazon Deals: Link supports the forum Black Friday 2024 | Amazon.co.uk Black Friday is an...
Admin1
Merry Christmas and Happy New Year from Tilers Forums! 2025 should be pretty good. The new...
Tilers Community Any of you members of Tilers Community on Facebook? They do a raffle where...
Colin from Accounts
The Welcome Thread Welcome to Tilers Talk people. :) This is not a big forum as you can see...
Admin1
Brand New Now Instock at Tile Choice - Arden Tiles 🚨🚨 Brand New Now Instock at Tile Choice 🚨🚨...
Admin1
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
