Discuss Newbie Questions in the British & UK Tiling Forum area at TilersForums.com.
colin178
Hi everyone
Since posting my introduction last week i have been trawling through all the posts starting at the back so still a long way to go!
I have a couple of questions im sure you guys will be able to answer.
Can someone explain what single part and two part adhesives are?
When talking about a tile staff or gauging rod, is that just a length of 2" x 1" with several marks of the tiles width on it, or is there a special tool?
Thanks alot
Colin
jamie B
Hi everyone
Thanks alot
Colin
Hi Colin,
Single part adhesive is usually powder that will be mixed with water.
Two part will be a powder that will be mixed with the appropriate liquid additive supplied ( to give different properties ie. more flexibility etc.)
these are usually designed and suited to varying applications ..so check which before you use!
As for a gauging stick..yep you got it, just made up usually on the job (dependent on size of tiles) just the mark of the tile plus your joint on the stick to give you an easier guide for setting out..come in very handy on large floors going through different rooms etc.
Hope this helps!:thumbsup:
Reply to Newbie Questions in the British & UK Tiling Forum area at TilersForums.com
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
Afternoon all, Another newbie question here. Got some great advice last time so hoping you...
2 3
11K
p4ulo
Not a question, but a suprising observation of an illusion! My next task has been to come up...
bcd-87
11K
Rizzle from the Portizzle
Newbie Questions
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
