Discuss Newbie in the UK Tiling Forum area at TilersForums.com.
paulprior
Hi everyone, i'm Paul and i am new to this forum.
I have done some small tiling jobs before, very slowly but i am now building my own house and would like to do all the tiling myself.
I have picked up a used Rubi TX700 tile breaker as my first tiles are black / grey porcelain 600*300 floor tiles with a riven slate effect on top, how do i know how hard these are and should i use the 10mm or 18mm scoring wheel?
Also, in the past i have generally used 300*300 and just put the cement onto the base of the tile and then lay it, is this ok?
reading my tile cement it says i should use a watered down mix of something before applying the cement to the ply on the floor, is this necessary, i have a 4mm ply above 22mm wooden boards, the ply is to get the height correct to the wooden floorboards outside the bathroom.
Any suggestions greatly appreciated
Paul
Reply to Newbie in the UK Tiling Forum area at TilersForums.com
    • Friendly
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Newbie
