Hi Guys & Girls
Iv been tiling for just over two years now. Needed a career change after years of unfulfilling jobs so decided to bit the bullet and go self employed. Started by doing a 6 week course then following a tiller round (chief tea maker) and started with small jobs. Im over two years in now and have not looked back. Still being new I stick to bathrooms (not wet rooms) and floors.
Anyway I have got to the stage where I am not able to ask other Tilers how they do things so opinions from you fine people please.
1: Window reveal - How do you guys keep the cuts clean around the window reveal. I use a rubi cuter but this leaves rough edges on tiles. Wet cutter (best finish IMO) is not an option for most jobs. I use sand paper to smooth off the edges and an electric sander some times but I am never completely happy. Is there another way. The long tiles on top of the window look the worst. I like to butt the trim right up to the tiles. I am after a finish to match the look of a non cut edge of a tile (within reason).
2: Battens - For example if I am starting with a full tile from the bath and run the tiles around the wall I batten it off. Question is how do you guys then work down. I am currently removing the batten when dry and laying the next row and battening it off again. This time consuming and a pain with solid walls. I end up holing the batten in place with silicone and wooden wedges. Is there an easier way?
I normally work in properties with terrible walls so If i need to pack it out trying to hold the batten in place becomes harder.
Cheers for the gems of wisdom in advance
