Hey all, sorry for the delay. I've been occupied elsewhere...
I notice a few of the most recent posts are still suggesting the plumbing is leaking etc etc. I dunno how many times I need to say it but it wasn't, isn't and never has been.
Anyways. Some points...
Bear in my when I was testing the leak I was spraying the shower head directly onto 1 place constantly, so it would exaggerate it. It's not a major leak, but it's a leak none-the-less.
I didn't feel I needed to and indeed wanted to take the bottom row of tiles off. On further examination of the leaking area in question I could see the grout was deep into the joint and could easily get another 1mm+ of more grout in there.
I think the leak was probably down to a number of things:
- Cheapest of the cheap, non flexible grout
- Thickness of grout in the joint/spot
- Possible lack of adhesive behind the joint/spot where it leaks
- Obviously, lack of Silicon in the vertical corner is a major reason for the leak in that particular area.
- Missing Silicon between bath and wall in that area (there was a gap, I discovered..) and obviously the tanking wasn't lipped onto the bath which I admit I didn't think of, but I still think it would be very very tricky to do as the edge of the bath are rounded..
So if the grout is crap and there's not much thickness in that particular joint then being porus water isn't going to take long to get through it. Or so that's the conclusion I reached.
So here's what *I* did. I'm sure some of you may think it's a "bodge". I appreciate it's not ideal but taking of rows of tiles after the bathroom has been completed isn't either and is OTT in my opinion given the nature of the leak. Had we not been living in the house YES I might have had the tiler come back, take the tiles off etc etc
First thing I did was get some more Silicon up between the bath edge and the wall. This was straight forward given the leak was at the tap end and the pboard was stopped just where the top lip of the bath started. I'm 100% confident all the Silicon I put in alone would stop the water dripping down the edge of the bath onto the floor but obviously that's the just one thing, it doesn't stop the water getting through the grout in the first place.
Second thing I did was to buy some better quality grout. Raked out the leaking joint area and applied some grout thicker than it was before. The joint looks better now, more solid.
I then sealed the grout with Seal Guard(£30 a can!!) and siliconed in the vertical corner joint.
That fixed it....I know some of you will frown upon this but I didn't want the hassle of ripping tiles off.
I did the fix, not the tiler. I learnt some lessons and will know better the next time I employ a tiler....
Here's the thing. I asked the tiler what he would have done if he'd done the whole bathroom and he said he only tanks for wetrooms and would have just used regular p-board. If he used the same grout on other jobs in combination with regular p-board you can imagine how it would just soak up any leaks. The mere fact that I had tanked and NOT lipped it, allowed the water to run down the wall and make the leak known.
We own a few rentals and I have a bit of experience with trades. As a customer you assume a tradesman knows his job inside out but I've discovered *I* need to have background knowledge just to make sure things are done correctly... it's very difficult in some cases. I still think the tiler is a good tiler in the asthetics of job but obviously his choice of materials and knowledge of certain things lets him down. How many customers are going to know this though?
All in all, a frustrating experience but had it not have happened next time I had some tiling work done I might have let the tiler use sub-
standard grout/addy. I certainly won't be doing that again.
