ConfusedTiler
Hi
Just found this forum and thought it would be a good place to ask some questions for my first tiling job!
I have my kitchen fitted including floor tiling and after a bad experience with our builders I am left in a position where I need to tile the walls myself.
I have a few questions that need answering before I take on this task...
Firstly the tiles are roughly 20cm tall and 30cm wide (landscape - give or take a few cm) and the gap in which they are going between our worktop and cupboards is just under the height of two tiles on top of each other in a landscape position. However, we have a windowsill in the middle which is about a tile high and a few cm. We also have a slightly unleveled worktop.
We are left wondering whether we start the tiles at the windowsill level and cut a small sliver at bottoms of the tiles in order to keep the middle a straight line... or keep the tiles and the worktop straight (by starting the tiles on the worktop and working upwards) and have the cut tiles underneath the cupboards, leaving a small sliver at the top just before the windowsill...
Also where is the best place to start tiling from? The corners of the room or above the sink/hob ..... ??
Any advice anyone can offer would be a massive help 🙂
Thank you,
An extremely confused tiler!
Thank you,
