Old School Grouting
The old way of grouting the quarries was to spread the wet Sand and cement into the joints then mix dry sand and cement (dryers) and scatter all over the floor and rub like hell,then later wet sawdust to clean it all up no washing of that i can remember, and your white grout was white cementt was and to stop it going off so quick in the joints add a little washing up liquid
That's how I was taught to grout quarries. Must admit I use wide joint now though.
Yep, that's how I was taught to grout, either using dry grout powder to fill joints or dry s&c mix, and silver sand or sawdust and rags to clean off.
Never washed a floor clean, always a dry polish.
Never used white cement for walls tho!
Just a little bit before my time.
Not much by the sounds of it tho! Haha
No.....lol
Can't say I've ever spread grout powder over joints to make them full.
I still use additives to make grout flexible. Bal wide joint and gt1 add mix you will not find a more flexible grout imo.
I do still grout using a good old sponge....can't get on with those wash boy contraptions ....I always end up over wetting the joints.
I'm old enough to remember that, it was with sand and cement installation.
Spread your driers and rub up flush joints and clean off with saw dust, pucker job on quarries and twin tiles.
Also used to sometimes "linseed oil " the quarry's after cleaned and swept with either dry mix or sawdust.... Use to cover up the "bloom" if they were laid into screed with a slurry mix.... Ah ...the good ol days!!
Old School Grouting
Flintstone,
gazmcd72,
Flintstone,
gazmcd72,
