Guest viewing is limited
Discuss Ooops who did the plasterboarding ? in the Canada Tile Advice area at TilersForums.com.
Gazzer
Started a job this afternoon, prepping out with backerboards on the bathroom and ensuite floors but noticed the lack of a waste pipe from the shower. So cant fix the boards in the Ensuite but more concerned that all the plasterboards have been fixed backwards , printed side facing out !!!! As far as I am aware its light side is the facing side unless something has changed recently ?
Diamond Pool Finishers
Yep when i was plastering we used to fix the board gray side -out for skimming as we were told that it had more suction !! and cream/lighters side out for decretive finishes !! lol, funny i posted a question on the plasterers forum today about plasterboard scrim, as now its all cotton with a selfe-adhisive side , when it used to do loads of skimming there was hessian/ jute scrim or cotton both to be beded-in to plaster ...... :thumbsup: lets hope he scew-fixed it !! i still have a big box of board nails in the lock-up !!
Colour Republic
Rough side for tiling according to bs
so it does
6.2.4.2 Sheets and boards
Sheets and boards include the materials listed in 6.1.2.6, except
plasterboards; sheets or boards should be adequately braced to
provide a rigid surface, be free from any springiness and surface
undulations and undergo no subsequent distortion during and after
completion of the tiling. Wherever possible, the boards should be
screwed, not nailed, to the supporting framework.
In general, where the sheet or board has a smooth and a rough side,
the latter should be used for tiling.
The surface to receive the tiles
should be clean and free from dust and other forms of
contamination.
but then....
6.2.4.3 Plasterboards
Gypsum plasterboard is generally suitable as a background for tiling,
but as considerable differences occur in usage between housing and
public buildings, consideration should be given to the plasterboard
specification and the fixing system.
Plasterboard should conform to BS EN 520. Plasterboard is generally
unsuitable for frequently wetted areas, see BS 5385-4 for further
guidance for wet conditions; where there is exposure to moisture,
e.g. splash backs, the plasterboard should either be type H or
pre-primed and the perimeter sealed.
The following precautions should be observed.
a) When fi xing to timber framing or battening, 12.5 mm board
should be used as a minimum thickness, with stiffening noggings
where necessary.
b) Boards should be positively fi xed by either nailing or screwing
over the complete area.
c) Where boards are not fi xed to timber backgrounds, reference
should be made to BS 8212 or the recommendations for the
proprietary system by the manufacturer.
d) The weight of tiling should not exceed 32 kg/m2, generally
equivalent to tiles with a thickness of 12.5 mm or natural stone
tiles with a thickness of 10 mm.
e) Boards should not become damp either during storage or after
installation.
f) Plasterboard wall linings not fi xed by nails or screws should be
allowed to stand for ten days before tiling commences.
g) Where tiling heights exceed 2 400 mm, reference should be
made to the recommendations of the plasterboard
manufacturer.
h) The tiles should be fi xed directly on the paper facing of the
plasterboards in accordance with the adhesive manufacturer’s
instructions.
widler
1,328
England
I always got told to board writing facing inwards,cos that is where the paper overlaps,it can bubble when skimmed!
Houses I've ripped out what have been done in the 70s or before with plasterboard were always boarded the same,writing in,never ever heard of writing facing out (I have done it before myself when over cut a board back to front,in a moment of numptyness never had a problem :)
Colour Republic
A touch of contradiction ??
Maybe not, i missed an important word
plasterboards
contamination.
Reply to Ooops who did the plasterboarding ? in the Canada Tile Advice area at TilersForums.com
Hi All, I am in the middle of sorting out my family bathroom, to begin with I have removed the...
lizzardtong
L
Afternoon all. Have recently said hello to theforum and finally got around to posing some...
Boondocker
Hi all, my bathroom tiles are circa 1990, ie horrific so need to go. Unless times have changed...
TJ Smiler
Our shower has been dripping for about six months, since we changed the boiler to a combi. This...
5K
Martino
I
I'll set the scene. The in laws invited us round for a BBQ yesterday, and these are always well...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
