Outdoor 20mm Porcelain 60 x 60 slabs How to install ? Help!
What is best way to lay outside 20mm Porcelain patio,
Would I compact soil, add hardcore and compact (How deep for hardcore) then add slurry mix of 4 parts sharp sand and 1 part concrete and lay tiles on top or as someone suggested set concrete base on top of hardcore and glue down using 5 mm spacers for brush in grout. Any advice would be most welcome, thank you regards David
I did one last year/early this year.I bedded on to a cement base,also you’ll need to prime each tile reversel side,with SBR mixed with cement mix,paint it on,3-4 inch hardcore whackered down,i then used a resin grout which you brush/force in to joints,this sets solid,no mess,sweep up excess.
DIY Tiling Forum
The Famous Forry,
The Famous Forry,
The Famous Forry,
The Famous Forry,
