Discuss Outside floor tiles - Grouting advice in the Best Floor Tiles area at TilersForums.com.
Our builder laid fabulous black 1200 x 600 tiles around our house and also on a large patio.
He used Fast Point brush in grout and it looked great for a while.
Unfortunately, the grout is all falling out and we have never been able to powerwash by any means as the grout comes out too.
I notice that the depth of the 12mm gap between the tiles is sometimes only about 5mm, so I can see why perhaps this is happening.
I'd obviously like to fix it.
I can see 2 possible solutions and I am really hoping that the first will work (my reason for posting).
1. I am thinking of powerwashing the old grout out. I now this will be fairly easy. I could then use different grout.
Would this work? Is there enough depth for grout to hold? What grout is recommended? Will it bond with the tile cement?
Otherwise:
2. I use a carefully aligned track saw with a diamond blade and cut out the fixing cement to a greater depth and replace the grout (again what would be best)?
This sounds like a lot of work as I have about 75 square metres of tiles and I hope to avoid this.
Or is there another way?
On a separate note - I see he has not put in anything to deal with expansion and the black tiles do get hot! I have had one crack so I guess this must be why. I am guessing I need to consider this if I can replace the grout.
Any advice here would be really appreciated.
J Sid
If the tiles are solid then I'd clean old grout out. Try to do it by hand if you can, I'd use a angle grinder myself as a power washer will force water under them and it will need to be dry before re grouting. I'd use bal wide joint or ardex FL floor grout.
Really needs doing before winter as a cold/freezing will start doing damage and slabs will soon become un bonded
Dave
Subscribed
389,933
1,000,000
Co.Durham
The joint filler used could well have not consolidated sufficiently in a narrow joint and
a reason for grout breaking away could be freeze/thaw from a couple winters.
Rake it all out and use a grout suitable for the joint width and not one of those brush in joint filling products, Tile grout would be more suitable for porcelain and harsh weather.
Thanks for all this. I shall replace the grout soon with some more appropriate product.
I still think that the tiles are concrete though and not porcelain.
The text on the page I got through a quick internet search says
Concrete Project is the full-thickness porcelain stoneware from ImolaCeramica made for modern architecture and design covering solutions. The concrete is turned into a tile with a clear contemporary mood
So there seems to be a mismatch. I think the company copied just that line from the Italian Imola Ceramica website. Here it says:
Concrete project.
The concrete is turned into a tile with a clear contemporary mood, designed to inspire and surround exterior surfaces, but also ventilated facades and high-traffic public spaces. Its minimalist style features in flooring that is highly modular in different sizes depending on requirements and the desired visual effect.
Boggs
1,118
Uk
Ah, I never knew. That is very interesting. I really appreciate you looking into this, it has been extremely helpful. It will also help me convince the missus that it really does need doing.
I had better get moving then. Just need this weather to get better.
One final question - should I add Admix GT1 if I get the Bal wide joint grout?
Reply to Outside floor tiles - Grouting advice in the Best Floor Tiles area at TilersForums.com
Our house was renovated 5 years ago, builders were pretty shoddy. One of our shower rooms is...
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
Hi, Just wondering what the general consensus is with grout for a shower. I have epoxy grouted...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Hi, I've laid an external porcelain patio on a sand and cement bed with ultrascape priming...
Nottingham
What member type are you?
  1. DIY Wall and Floor Tiler
Best Floor Tiles
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 2 1.3%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
