Oven and hob diversity
  • Thread starter Thread starter littlespark
  • Start date Start date
Morning lads.
Todays job is to go to in laws and firstly replace a cooker hood that went fzzzzz! Which is straightforward.
But I’ve also got to change the gas hob for an electric. Following an incident where gas was left on by increasingly forgetful mother in law.
There is an existing 32A protected, 6mm cable cooker supply switch that controls a double oven at the moment…. Total rated load 4.8kW
The new hob is 5 ring ceramic, rated 7350W
What’s the diversity on a 5 ring hob, and could it share the cooker supply? Even if I update the 32 to a 40. (Old mk sentry board, hoping I’ve got spare mcbs)
I’m all set to run in a new 6mm through the wall into the garage and back to the board… but wanted to save a bit of time with this being a family job.
Continue reading...
Electrical Advice
Tags Tags
None
littlespark,
littlespark,
