Discuss paintable dpm in the Australia Tiling Forum area at TilersForums.com.
judge
1,078
Can anyone recommend a liquid dpm to tile onto ?(will be tiling over with reclaimed quarrys).The floor is concrete,in good condition(ive no clue how old it is)But when there has been a lot of rain a condensation appears on the surface.Customer says it doesnt gather water but enough to get your socks damp if you walk on it.Part of the floor is slightly below ground level but he is in the process of digging drainage outside this area.I can only assume there is no dpm in the existing floor so am looking for the right system to apply before tiling :smilewinkgrin:
CJ
1,088
Somerset
image.jpg Used this a couple of times.
Ajax123
1,213
Lincolnshire
Merlin barrier coat from Mersin coatings ltd.
be wary though as liquid Dpms are not designed for rising damp and this sounds like it needs more serious consideration. The hydrostatic pressure could push the Dpm off the concrete surface if you're not careful..... Tanking may be a better solution using a basement style tanking system.
Reply to paintable dpm in the Australia Tiling Forum area at TilersForums.com
I think my question has been partly answered by @Andrew near the very end of this thread, but...
Just Rizzle
My bathroom is on the ground floor of my circa 1900 end of terrace house in Sussex. It had lino...
33K
J Sid
Hi I am laying 14 sqm of 12-15mm sandstone tiles onto a concrete 1930's floor. DPM is unknown -...
6K
matty
F
Hi, I want to retile one of my rooms, but first I need to raise the floor with 50mm unbonded...
5K
fro0tylo0py
F
hi,still finding my way round here so forgive if the answer is elsewhere. i have to prepare...
bramleyman
Tilers Forums on FB
