Pimp my Grinder up please
Just struggled with a porcelain floor 600x300 tiles and now I have another DIY job coming up with porcelain I have a wet table saw that I call Mr Chippy and after reading here my best option is an angle grinder - which I already have I now know thanks to you guys the type of cutting disc to get, 1-2mm and wavy curly patten but from where, I see 2 suppliers mentioned quite often ritelines and ATS diamond tools. I could also do with some sort of finishing/ grinding discs to take off very thin strips from my miss measurements but which one ?
Ritelines? Not on here, can’t say I’ve ever seen them here.
Every material behaves differently with different types of blade.
Three main types.
Turbo
Mesh
Continuous rim.
Each have their place.
But that’s the trick, finding the one that works for the material you’re using at the time.
Not really any hard and fast rules, and it depends what level of finish you expect/require.
Three main types.
Turbo
Mesh
Continuous rim.
Here
Rubi viper blade works for me. A few other people I know swear by it aswell. But again depends on the user a lot of the time.
Ok no problems but where then or who apart from the norm big retailers I could walk into and pay over the odds like Tops for example
seems like I should get on better than my wet bench with any thin angle grinder blade but what about when it comes to sanding grinding - adjusting my crap cut in the first place what should I be looking at for the fine tuning down to my line
Filip,
Old Mod,
Filip,
Old Mod,
