Planning a level access shower
Thanks. I thought that Hardiebacker was meant to replace plasterboard in shower/bath areas. I'm clearly mistaken or have been misinformed along the way.
Just bought 14 from Selco. I believe I will be charged a restocking fee. Maybe I could board over the blockwork in the non wet areas with it?
This is from the Hardiebacker website. I have been mis-sold!
"HardieBacker® tile backerboard is a fibre cement tiling backerboard especially suited to installation as a tiling base in wet areas. HardieBacker is water resistant, fire resistant and mould resistant; and is often used as alternative to plywood, chipboard, plasterboard as tiling backer board."
I've recently tiled on a delta Thames tray and thought it was good and the waste was also good. Can't go wrong with delta / pcs in my opinion
Water resistant, meaning it won't break down but will allow water to pass through. You need water proof in the wet area. The Hardie is fine in the dry areas.
The thought of cutting, shaping, handling and fixing 12mm Hardiebacker onto walls vs the ease of cutting, handling and fixing of a cement faced foam board- you’ll be thanking the people of the forum which will outweigh the hassle of returning the Hardiebacker.
Only problem I can see is that the studs are 400 centres which is ok for Hardiebacker, but the other type boards appear to be 600 wide. So can I place them horizontally without fixing a load of extra noggins?
The boards won’t be supported properly when placed horizontally. I would pop some extra studs in and put some long boards in. I tend to use CLS. It’s straighter.
Tanking and Wetrooms
Al Getaroundtuit,
Raccus,
Al Getaroundtuit,
Raccus,
