Discuss plaster not going off in the UK Tiling Forum area at TilersForums.com.
F
faithhealer
I had a plasterer come in to plaster a wall today. the wall varied from 'down to brickwork (Looked damp if I'm honest) to new plasterboard. my plasterer said that a handful of cement speeds up the drying time of (bonding) plaster!! Anyway, first coat of about 10/12mm didn't look as if it was drying (about an hour) so he put another 10/12mm on and left it. Still not setting when I left later on. Checked the 'use by dates', bonding ok but cement well out' Will I be hacking it off tomorrow do you think lads?
Ajax123
1,213
Lincolnshire
Most gypsum plasters (anhydrite screed included in this) will tolerate a small quantity of clean ordinary portland cement. Different manufacturers argue on the percentage but vary between 3 and 5%. This can actually be beneficial in terms of surface hardness as the cement hydrates relatively quickly. It does have the disadvantage of reducing the flexural strength of the material. In fact most Hemi Hydrate Screed materials have around 4% cement in them.
If however, as is more likely these days, he has used a modern bagged cement, many of which contain plasticisers (e.g. Multicem and Mastercrete) these can severely retard the setting of the gypsum as they impede the chrystalisation process.
I occasionally see issues where a concrete mixer has failed to wash out thoroughly and the anhydrite gets contaminated with polycarboxylate plasticiser and it can take several days for the screed to go hard. Unless there has been a significant level of plas added though it will go hard it could just take several days. The dampness in the wall will not have helped and ought to have been dealt with first as it could affect the long term bond of the plaster to the wall itself.
In fact when I have wanted to slow down the setting time of out of date plaster I have added a couple of cap fuls of detol (acid retarder) and have been able to work with it. Mind you the smell was horrid.
If it was a really modern cement which is blended with GGBS (a cement replacement) then you might as well take it off the wall now. This latter is unlikely. I am not sure phoenix (trade name for Blue Circle) is available in bagged form. GGBS and Gypsum are very poor bedfellows and the latter leads to poly sulphide attack in the Gypsum core causing aggresively expansive degeneration of the gypsum.
The shelf life of cement is to do with the removal a few years ago of Chromium 6 from the cement. This acts as a stabilising agent to prevent the cement hydrating whilst in storage. Hexavalent Chromium is probably the best material for this purpose but unfortunately it is also responsible for the the dermatitis people got when using cement. It was replaced predominantly with Ferrous Oxide which is less effective so manufacturers now put a 3 to 6 month shelf life on cement but at least it does not give you cancer any more.
I think realistically it is most likey the result of the addition of plasticised cement and whilst it might take longer than it ought to go hard there is little need to worry.
doug boardley
I was gonna say that too:lol::lol:
Scott
^^^ WOW! He knows his stuff huh! I bet that wasnt in the Marks and Spencer book! :lol:
On a serious note i have seen sparkys put bonding and cement together regularly to set pattresses in the wall. It goes off real quick. I have used it one or twice round the edge of a bath to speed the drying time before a top coat of hardwall. Never had a problem with it but then its only been in small quantities
Reply to plaster not going off in the UK Tiling Forum area at TilersForums.com
  • Sticky
Sorry for asking a question that I already think i know the answer to but I just need...
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
