Discuss plaster not going off in the British & UK Tiling Forum area at TilersForums.com.
mikethetile
i tried to put brick acid in an alluminium bucket , wow!!!! it whent mad!!!!:yikes:
I worked with a hoddie who after watching the ground workers cleaning their shovels with brick acid decided to leave his hod soaking overnight
next morning all that was left was the shaft:lol:
Ajax123
1,213
Lincolnshire
don't think the cement will work he needs to add plain old table salt to the mix that will get it moving
Ajax ever tried brown sugar on fresh concrete (driveways mainly) to acieve the pebble effect works a treat:8:
never done it with brown sugar but I have done it using other retarders. MOst old fashioned cement retarders are sugar based - usually based on plant sugars and wood resins. They are a bit more advanced and synthetic these days cos chopping down all the trees to stop consrete going off too quickly was considered not a great idea.
I guess with the brown sughar you would sprinkle it on and trowel it in then wash it off the following day like we currently do with exposed aggregate concrete driveways. Refined (white) sugar would do the same thing but would probably have a much deeper effect.
Never come acroos the table salt idea though. Will probably have to mix some up and try it now.........:thumbsup:
F
faithhealer
Nobody has mentioned the old Ettringnite failure..???.. portland cement and gypsum..:thumbsdown:
As I said dave, thats what I thought first off but as I said didn't like to argue the point 'til I had more info. Printed this thread off today and gave it to him. Still waiting for a reply on the plasterers forum by the way, much traffic on there these days?
jay
you mix raw sugar and water fairley strong then with a eeeerrrr back pack spray unit (garden spray unit) apply it to the surface like you would normaly with exposed ag concrete:8:
jay
so, ( sorry for deviating Faith:oops:) if I lay my patio concrete slad, sprinkle sugar over it, it would leave some of the aggregate exposed? and then I could get a polisher and polish it off to leave a terrazzo effect?:daisy:
nah just get concrete supplier to use pebbles ( little roundish rocks ) instead of agregate then you can wash the top of or just get it polished looks neat:8:
Tecnik2000
I had a plasterer come in to plaster a wall today. the wall varied from 'down to brickwork (Looked damp if I'm honest) to new plasterboard. my plasterer said that a handful of cement speeds up the drying time of (bonding) plaster!! Anyway, first coat of about 10/12mm didn't look as if it was drying (about an hour) so he put another 10/12mm on and left it. Still not setting when I left later on. Checked the 'use by dates', bonding ok but cement well out' Will I be hacking it off tomorrow do you think lads?
I'm slightly confused ,you used the term plaster, in my experience,plaster is only applied in thin coats up to about4- 5mm, & as a finish. is this a render coat or a one coat finishing system.Like thistle universal,or carlite
F
faithhealer
Excuse my terminology, if it's wrong,but the first two coats were 'bonding' and final skim was a 'multi finish plaster
doug boardley
bonding is a gypsum basecoat, you skim onto it.
Reply to plaster not going off in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Sorry for asking a question that I already think i know the answer to but I just need...
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
