Discuss plasterboard question. in the Canada Tile Advice area at TilersForums.com.
Yes I read that about weber gear , do you fill taper as you tile or do you fill first let dry then tile.
I only prime the exposed gypsum edges on plasterboard.
Just a couple of points while reading this thread -
1) check the weights of large format tiles prior to fixing on plasterboard ( bare and skimmed)
2) do not use a tubbed dispersion adhesive on large format porcelain tiles.
Reply to plasterboard question. in the Canada Tile Advice area at TilersForums.com
