Discuss PLasterboard? in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
I would check on regulations if I were you, I believe, and it would be good practise anyway, that you may have to use epoxy grout for food prep areas. Would also use White Star myself, BAL info doesn't mention suitability of Blue Star for commercial areas but that is just me, the extra cost involved for using a better adhesive is, in my opinion, never wasted - helps me sleep better knowing things aren't going to fall off.
The more experienced guys on here will I'm sure, also point you in the right direction direction.
DHTiling
use bal white star and grout with bal micro-flex ideal for food areas...
white star is highly flexible so itwill cope with any moisture expansion and the micro-flex has built in microban so no problems with listeria/salmellona or mould growth, then use bal microban Silicon to seal joints etc... hope this helps mate.. dave.........
GazTech
Listen to your Uncle Dave,he's spot on.Government have said that any grouting to be done in hospitals has to be with microban protected grout,being that BAL researched and produce it speaks for itself.Personally I would use white star and prime 1st with Bal prime APD
GazTech
I know Gaz, your advice is spot on mate (as always), was just re-enforcing the fact that you must prime plasterboard as some others have advised otherwise.
I would not dare challenge your knowledge of BAL products or tiling mate, maybe your sanity though:wink_smile:
Thanks Martin I do of course question my own sanity. PS can you give Reaper his retail tag plz I would be eternally gratefull:icon10:
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
If you think you're not going to make any csh dont do the job. Call them and say you'e foun out tht you need to use a different type of adhesives / grout than normal due to the area it's in although your labour price wont change.
If they want to pay a bit extra do the job. But dont get out of bed for nothing.
Gaz, given your new friend the Retailer tag as requested. The he is named Sandra though I think so I assume he's a She really. (judging by their email address anyway)
Reply to PLasterboard? in the British & UK Tiling Forum area at TilersForums.com
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
PLasterboard?
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
