Setting Out Please help me set out
Discuss Please help me set out in the DIY Tiling Forum area at TilersForums.com.
F
Fourcircles
Hello,
Can anyone help me with setting out for a bathroom wall inclusive of a window? I am using 600x300 in a running bond pattern. I have the window centre and I'm working from that with a tile gauge, but I'm left with slithers on the second row, even when moving across half a tile.
Any advice?
Cheers
F
Fourcircles
How small is the slither? Can you cheat and make those tiles slightly longer to lose the slither? Does tiling the other walls first lose the slither?
The slither is only 50mm! I suppose I could lengthen the tiles but then I'll obviously lose the centre of the window. Would this look bad?
Cheers
And if you are going to amend your drawing, would be helpful to explore other possibilities, can I have cill height, window head height and distance between each window reveal and their adjacent corner please.
It's way too late to be deducting figures from each other when I've been doing this all day long. :)
Appreciate it, thank you.
F
Fourcircles
No, thank you for helping me!
Here's a picture of the wall itself with the measurements you asked for (I think I've included them all). If there's anything else you need, please let me know.
Thanks again.
Close, :D I have no reference point as to the location of the window I'm afraid.
The 1188mm width of the window could effectively be anywhere along the 1895mm of the wall.
So the measurement between the reveal of the window and their adjoins corner would really help too.
Thank you.
Sorry to be a pain, and I'll check back in the morning.
Bond
528
Highland
Hello,
Any advice?
Cheers
Assuming that I am understanding the sketch correctly.
Personally faced with this , I would start with a cut tile of half the distance between window and corner, e.g. 175mm, leaving a cut of approximately 520mm at the opposite end, whilst not exactly half bond, you will achieve simitary albeit on alternate courses, between window and corners, if you get what I mean.
Hope this helps.
F
Fourcircles
Thank you.
Sorry about that, if I'm understanding you correctly, this should help!
F
Fourcircles
Hope this helps.
I think this is the best option so far. Thanks for the advice.
F
Fourcircles
how does the bond on the already tiled right hand wall finish, could you continue with the offcuts? I.e if your large tile is at 400 use the 200 cut and the half bond at 100 use the 500 cut.
Does that make sense??
Yes, it does. I've attached a pictured of the tiled wall below. The large tile is at 535mm which only leaves 65mm. I suppose I could extend this to 100mm? Or even go to 172mm as mentioned above? What do you think?
Cheers
Reply to Please help me set out in the DIY Tiling Forum area at TilersForums.com
Dear Tilers, my husband has done a lot of tiling, but would really like your advice please. He...
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Setting Out
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
