Hello,
Can anyone help me with setting out for a bathroom wall inclusive of a window? I am using 600x300 in a running bond pattern. I have the window centre and I'm working from that with a tile gauge, but I'm left with slithers on the second row, even when moving across half a tile.
Any advice?
Cheers
Assuming that I am understanding the sketch correctly.
Personally faced with this , I would start with a cut tile of half the distance between window and corner, e.g. 175mm, leaving a cut of approximately 520mm at the opposite end, whilst not exactly half bond, you will achieve simitary albeit on alternate courses, between window and corners, if you get what I mean.
Hope this helps.
